strategy to enhance of time steps
Old   June 6, 2016, 03:27
Red face strategy to enhance of time steps
faraz
farazmardazad is on a distinguished road
Hi all,
I try to simulate an unsteady multiphase issue with vof model, but time step size for continuity convergence is order of e^10-6, and flow time is about an hour, so i can't simulate it because of very high computational expense.
Are there a strategy to enhance time step size?
thank you for answers.
farazmardazad is offline   Reply With Quote
Old   June 7, 2016, 16:04
Matt
MBdonCFD is on a distinguished road
Can you describe how you arrived at your time step and why the total simulation time needs to be one hour?
MBdonCFD is offline   Reply With Quote
Old   June 7, 2016, 17:34
Cool
faraz
I use variable time step with courant number=2, time step automatically change to near 10^-6. i simulate a big tank fill process that have about one hour filling time.
Old   June 7, 2016, 17:50
Filippo Maria Denaro
FMDenaro will become famous soon enoughFMDenaro will become famous soon enough
what about the physical dimensions of the tank, the size of the computational domain and the velocity?
FMDenaro is offline   Reply With Quote
Old   June 7, 2016, 18:03
faraz
volume of tank =5 cubic meter
number of mesh = 170000, but it's low
mass flow rate = 0.15 kg/s.
Old   June 7, 2016, 18:27
well, consider that in each direction ci = ui dt/ hi but, depending on the scheme you are using, the numerical stability does not depend only on the courant number but is it a combination with the diffusive constraint.
Are you using an explicit time integration?
Old   June 7, 2016, 18:53
faraz
No, i am using implicit formulation, because of pressure-based solver.
Old   June 8, 2016, 03:06
that should allow higher time step.... I suggest to check during the solution to write the values of max(ci) and max(alphai), this latter being the diffusive stability parameter.
But with your small time step the solution is physically acceptable after a certain amount of steps? I always suspect a bug in the solver.
Old   June 8, 2016, 06:45
Michael Prinkey
mprinkey will become famous soon enough
It is not clear to me if this is a commercial code, community code, or something you've developed. The time step will be determined by the smallest cell in the mesh. If you have a inlet tube and some transition cells feeding into the tank or, if you have applied boundary layer stretching near walls, some of those cells could have a very small length scale with a typical velocity value, and that makes the CFL number time step very small.
mprinkey is offline   Reply With Quote
Old   June 8, 2016, 07:08
I agree ... but he wrote of being using an implicit formulation and that makes me having some doubts...for that reason I suggested to write the resulting max cfl in the computation
Thread Tools
Trackbacks are On
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 12 March 21, 2016 14:05
Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Mesh Utilities 57 February 1, 2015 09:25
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 9 January 3, 2012 09:06
