June 13, 2016, 10:11 |
corrugated line periodic boundary conditions
Andrew Brown
I am very new to Fluent and am trying to evaluate pressure drop through corrugated lines. I've heard there is a way to set a boundary conditions so that your geometry doesn't have to be so long. I think the idea is to let the outlet re-circulate to the inlet. The purpose here is to analyze the pressure drop through corrugated lines without having to create such a long section of pipe. Any advice will be greatly appreciated, thank you in advance. Ansys Fluent V16.2 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
