July 9, 2016, 18:16 |
meshing a pipe
E.T.
Rep Power: 10 |
Hi guys,
we generated a pipe in .stl format then we tried to to meshing , at first with named selection e defined inlet outlet but we couldn't define the fluid volume within the pipe, and because of that we couldn't do the meshing. I think the reason is because of the without caping the holes at both sides. And I tried to close these holes with creating surfaces in Spaceclaim but several times I tried but failed. Could you please help me how to do it in Spaceclaim before going to meshing step? I need your kind hlps friends. Kind REgards Last edited by drercardio; July 10, 2016 at 04:20. |
[ANSYS Meshing] Meshing a Simple Pipe With Different Diameters | Adnann | ANSYS Meshing & Geometry | 2 | May 16, 2016 03:38 |
[ICEM] ICEM "U" shaped pipe meshing | mshaux | ANSYS Meshing & Geometry | 2 | April 12, 2016 09:06 |
[ICEM] Hexa meshing branched pipe with different angles about its perimeter | fascinatedbyCFD | ANSYS Meshing & Geometry | 1 | November 19, 2015 10:11 |
[ICEM] Pipe 90 elbow joint meshing issue | sihaqqi | ANSYS Meshing & Geometry | 25 | April 17, 2015 04:59 |
Meshing of circular pipe in CFX-mesh | Fatnes | CFX | 3 | March 27, 2009 06:29 |
