July 12, 2016, 07:09 |
CFD CFX Air con on and off timer
Nomen Ose
Rep Power: 9 |
I successfully modelled a bus with diffusers and door. I got the simulation running and can see the change in air temperature when the door is open but I want to close the door after a number of minutes
How can I achieve this??? I know there is a way but I need help ASAP Regards, |
July 17, 2016, 09:34 |
Nomen Ose
Rep Power: 9 |
Can ANYONE help
July 17, 2016, 10:04 |
Jan
Rep Power: 12 |
The easiest was is, to make three differenz simulations.
1. Doors are closed 2. Doors are opend 3. Doors are closed again. For each simulations, you initialize with the end of the previous one. In CFD Post, you can combine the simulations. Then you can define a Key-Frame Animation in CFD Post, where you load another result file in a new key-frame. You also can define a interface at the door and define, if she is active or not. If not, it is treated as a wall. |
July 17, 2016, 10:12 |
Nomen Ose
Rep Power: 9 |
Thank you very much Jan, I will follow your advise and post on here if I need more help. Thanks again
Cheers |
July 18, 2016, 04:36 |
Nomen Ose
Rep Power: 9 |
I am having trouble combining the simulations and creating a keyframe simulation with the combined results. Could you shed more light on this aspect? How do I combine all 3 results ?
Regards, |
July 18, 2016, 11:07 |
Martin
Rep Power: 11 |
When you are performing a transient simulation, you could write an UDF which sets the mass flow rate at the door to zero after the doors are closed.
If not, the suggestion of jan is propably a good method. You can save the data file after each time step. Read the transient procedure in CFD post. |
