How to calculate CPU time in Linux system?
Old   February 22, 2000, 00:58
Default How to calculate CPU time in Linux system?
HS Dou
Hi,Everyone:
I am a new user of Linux system. Could anyone please tell me how to calculate excutive CPU time of a program in Linux system?
Before in Unix system, we use "mclock()."
Thanks in advance.
HS Dou
Old   February 22, 2000, 09:19
Default Re: How to calculate CPU time in NT system?
kang
I am thinking about the same question, but on NT platform. Any information would be appreciated.
Old   February 22, 2000, 09:20
Default Re: How to calculate CPU time in Linux system?
Sanjeev Kumar
You can use a command called "time" for that purpose.
Old   February 22, 2000, 09:29
clifford bradford
there should be some kind of 'time' command use the man pages. also most unix systems including linux have extensive profiling tools to let you see which subroutines in your code take most time and i think they can do things like calculate flops etc.
Old   February 22, 2000, 10:55
Bernard Parent
Use /usr/bin/time and then follow it by the name of your executable. I suggest not to use the shell built-in time function which you will invoke if you call 'time' instead of '/usr/bin/time'.
When your code will be done, the time will be outputted to stderr. Also note that this will only work if your code is non-threaded. For a threaded application (multi-CPU), there is sadly no way AFAIK to tell the CPU time on linux..
If you run your code in the background and want stdout and stderr redirected to files, here's what to type in at the bash prompt:
/usr/bin/time yourcode > scr.stdout 2> scr.stderr &
where 'yourcode' is the name of your executable.. The time required for execution will be outputted to scr.stderr, which should look something like:
72.13user 0.11system 1:16.13elapsed 94%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (5956major+626minor)pagefaults 0swaps
The first number preceding user is the number of CPU seconds the code required for completion.
have fun,
-bern
Old   February 22, 2000, 20:59
Marcio Aredes Martins
If you are a fortran user (Dec, Absoft or Microsoft) use the function called TIMEF(). This function calculate the CPU time in double precision.
Old   March 1, 2000, 22:38
Default Thanks very much for below help.
HS Dou
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
how to calculate the averaged mass flow along a line over time ? iampolaris OpenFOAM Post-Processing 0 March 10, 2011 22:03
Overflow problem in steady simulation ReeKo CFX 11 October 8, 2008 17:57
On the reduction of cpu time lee Main CFD Forum 4 March 7, 1999 22:02
