GIF-Animator
Old   February 4, 2000, 03:33
Default GIF-Animator
Detlef Schulze
Hi there, I am looking for a small GIF-Animator running under NT4.0 or Win 95/98. Programmes such as GIF-Construction Set are having to much overhead for my needs. What I need is: Setting up an animated GIF consisting of 2000 GIF-Files. Therefore, the programmes should be as small as possible. Fancy features like cropping, resizing etc. are not required. A must is: Selecting a whole bunch of GIF-Files at once (preferably all 2000) or running the programme in some sort of "batch" mode.
May be the CFD-community knows where to find such a programme?
Thank you Detlef
Old   February 4, 2000, 06:13
Default Re: GIF-Animator
Tim Franke
The shareware tool animation shop could be a possible solution to your problem. A 30-day trial version can be downloaded from http://www.jasc.com
Hope this helps,
Tim
Old   February 4, 2000, 12:21
Paul Hancock
You might also look at the ULEAD Gif Animator
http://www.ulead.com/runme.htm
Old   February 4, 2000, 15:10
Amadou Sowe
You may find the posting by Jonas on Jan 19 on Generating High quality Movies useful. Good luck.
Old   February 6, 2000, 17:46
Hi Detlef,
I use ImageMagick to create all my animations. Large animations can be easily made using a shell script or batchfile (Depending on your persuasion).
http://www.wizards.dupont.com/cristy/ImageMagick.html
When I display my GIF animations I use the Microsoft GIF animator. It is small with little extra frippery so doesn't eat up too much memory.
http://www.servethe.net/free-zone/giffer.html
Last year I did quite a bit of looking around for the best way to generate and present animations of my results. I found these two utilities to be the best I could find.
Glenn
DxFoam crash outputting gif mike_jaworski OpenFOAM Post-Processing 3 January 2, 2008 05:55
JAVA based .gif file animator Moritz Main CFD Forum 0 March 20, 2006 10:50
Gif files Alexander Siemens 2 December 9, 2003 16:18
GIF Files On Windows NT MK Siemens 9 October 26, 2000 11:06
