To define Boundary conditions of compressible fluid |
September 24, 2016, 02:58 |
raunak jung pandey
Rep Power: 9 |
I am doing a simulation of a fluidic oscillator.
In the experimental setup, one oscillator is mounted on a metal stand. Upstream of the fluidic oscillator it is supplied with pressurized air with a maximum pressure of 16 bars.A plenum is installed to provide homogeneous inflow conditions. The supply rate is controlled by a mass flow controller allowing a mass flow up to 28 g/s with an accuracy of 0.6%. http://https://drive.google.com/drive/folders/0BzoaED8WwBOWamptZXJaa3dQS1U?usp=sharing What boundary conditions should I apply for the simulation? I have used mass flow and static pressure outlet. But don't know how to apply effects of pressurized air. Please help me understand this problem. Thank You |
September 24, 2016, 03:32 |
Filippo Maria Denaro
Rep Power: 71 |
September 24, 2016, 12:08 |
Charles
Rep Power: 9 |
You can ignore the upstream air pressure (i.e. max 16bar) when you setup your model. That will over constrain your problem. If you measured the upstream pressure, it is a very good data for verify if your CFD model is correct and accurate.
September 24, 2016, 19:54 |
raunak jung pandey
Rep Power: 9 |
What will be the effect of upward pressurized air ? Do I need to change density at the inlet ? There is fairly a long inlet channel before the air reaches the nozzle .
September 24, 2016, 20:59 |
Charles
Rep Power: 9 |
The effect is included in your model though you do need properly set the inlet density if it is asked. When I said it is included, I mean the flow rate is indirectly linked to the upstream pressure. If however, you apply pressure and flow rate at the same time, the model might not converge because the input pressure and flow rate might not accurately coherent to generate a stead state flow.
September 24, 2016, 22:34 |
#6 | |
raunak jung pandey
Rep Power: 9 |
September 24, 2016, 23:32 |
Charles
Rep Power: 9 |
It becomes very interesting when comparing CFD result with experimental data; this will make CFD practical and useful. What's the difference?
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 11:14 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
