October 3, 2016, 13:32 |
Laminar or Turbulent simulation
Raj Narayan.G
Rep Power: 14 |
Hi All,
I am simulating laminar flow (Reynolds number of 500) in a channel with square and rectangular protrusions inside. From experimental studies conducted, it "seems" that flow turns turbulent. Should I simulate the flow as Turbulent flow and use SST model or laminar flow or use transition models? Please let me know your thoughts. |
October 3, 2016, 14:06 |
Filippo Maria Denaro
Rep Power: 71 |
it depends on the problem..if you have transition along the channel, that is the flow in inlet is laminar and then becomes turbulent, you have to use DNS or LES.
October 3, 2016, 14:15 |
Raj Narayan.G
Rep Power: 14 |
Thanks for your reply. I am trying to perform optimization and hence have to run multiple cases. Hence running a computationally intensive LES or DNS doesn't sound like a good option for me right now. I was wondering if any RANS options may be available.
October 13, 2016, 12:25 |
Transition RANS model
Alberto
Rep Power: 12 |
One of the best options for RANS transition simulations is he NEW k-omega-v2 model:
Maurin Lopez. D. K. Walters. “Prediction of transitional and fully turbulent free shear flows using an alternative to the laminar kinetic energy approach”. Journal of Turbulence, Vol 17, Iss. 3, 2016. https://www.researchgate.net/publica...nergy_approach This new model is an improvement (in theory and results) to the popular k-kl-omega model. Therefore the k-omega-v2 model is a reliable and robust model for transitional flows (see the paper). |
Defining regions of laminar and turbulent flows | raven | CFX | 7 | July 31, 2015 00:24 |
Is it a turbulent flow or laminar flow? | ringtail | Main CFD Forum | 9 | January 22, 2015 19:52 |
2D LES simulation of turbulent jet | adnan.nweilati | FLUENT | 0 | November 12, 2014 10:50 |
Use of laminar model for a turbulent flow | jcamilleri | Main CFD Forum | 1 | July 6, 2014 06:54 |
How to determinate turbulence scale in LES (laminar simulation)? | Franciswu21 | ANSYS | 0 | October 22, 2009 12:48 |
