Error appeared: "cx-restore-view: no views are stored"..Need help |
October 21, 2016, 04:46 |
Rep Power: 9 |
Hello everyone.
I'm trying to simulate a reactor whose reaction chamber is surrounded by porous walls and then by pressure bearing wall. between these two, there is water slightly pouring into reaction chamber. But the following are appearing. 1- Error: cx-restore-view: no views are stored Error Object: #f Setting Post Processing and Surfaces information ... Error: lvectorlength: wta(1) Error Object: () 2- How to improve its meshing to deal with the following error... WARNING: Mesh check failed. To get more detailed information about the mesh check failure increase the mesh check verbosity via the TUI command /mesh/check-verbosity. Fluent can also try to fix the mesh check problems via the TUI command /mesh/repair-improve/repair. Thanking in anticipation. |
October 24, 2016, 09:45 |
Rep Power: 11 |
this thread should be in the fluent forum. Anyhow http://www.cfd-online.com/Forums/flu...ws-stored.html gives a starting point for your first problem. Secondly, you should do what fluent suggests. /mesh/check-verbosity 3 /mesh/check see if you can find out what's wrong with the mesh. if faces are left handed, or minor problems occur, try repair it with the third command, perform check again. most of the times, it should be fixed then. good luck |
October 25, 2016, 01:08 |
Rep Power: 9 |
Thank You so much.
