May 30, 2000, 08:43 |
non linear continuity equation
I am working on a combustion problem in which i solve the continuity equation alongwith the species and the energy equations.(Pressure constant-low mach flow-momemtum eqn is not considered)The continuity equation is a nonlinear hyperbolic equation {rho=rho(r,t),v=v(r,t)}which has to be marched forward in radial direction to solve for radial velocity v,starting from an initially prescribed v. v is also to be used in the species and energy equations.I am unsure about the right approach to discretize and numerically implement this using the species and energy equations.Before solving for the continuity equation i discretize the species and energy equations and use the value of Y (mass fraction) and T in the equation of state to get an updated rho(n+1).I am not sure about handling the (rho*v) term which appears in the equation.I intend to linearize after discretizing the equation.I am using a crank nicholson scheme.Is this the sutable/appropriate approach.I would be grateful for any response Thanks in advance Venkat |
Display Modes | |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
continuity equation | Rafal | Main CFD Forum | 4 | November 29, 2006 10:27 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
