-   -   Tip Clearance in Transonic Compressors (http://www.cfd-online.com/Forums/main/2073-tip-clearance-transonic-compressors.html)
Behnam.H.Beheshti May 2, 2000 09:23
Hi everybody,
I am a PH.D student and I am going to start my thesis which is about studing flow field in the tip clearance of a transonic compressor. I would be so grateful if you tell me how I can start and if you introduce me some helpful references .
sincerely yours,
Behnam.H.Beheshti Sharif University of Technology
John C. Chien May 2, 2000 10:16
Re: Tip Clearance in Transonic Compressors
(1). Try to read the ASME/ Journal of Turbomachinery. And ASME turbomachinery conference papers.
clifford bradford May 2, 2000 15:56
try Budugur lakshminarayana's book on turbomachinery "fluid dynamics and heat transfer of turbomachinery" it's a good reference on anything to do with turbomachines. john also pointed you to some good reference journals. increasing papers are available online either in collections or at the authors homepage eg http://web.mit.edu/aeroastro/www/labs/GTL/ is mit's gas turbine lab homepage
Joergw Weidenfeller May 3, 2000 03:37
Look for the book: Compressor Aerodynamics by. N. A. Cumpsty. There are also a lot of references.
annie September 16, 2010 16:16
question
I read the Nasa report "Laser Anemometer Measurements in a Transonic Axial Flow Fan Rotor" that is about NASA rotor 67 and it has a lot of data about the 3D geometry about this blade,and I tried to produce the 3D geometry of this blade that I need it immediately but I couldn't. Does any body have the 3D geometry of this blade in IGES or STEP format?
Thanks
Far September 17, 2010 18:50
you have couple of papers on compressor , I am not getting your point?
annie September 18, 2010 01:52
Thanks
bigbigbird May 20, 2013 21:47
Originally Posted by Joergw Weidenfeller
;8581
Do you have an e-book of Compressor Aerodynamics by .N.A.Cumpsty.If you have please send one to me.My e-mail was:jixiexueyuanliuwei@163.com
thank you very much.
