Turbulence problem is dead
Old   May 21, 2000, 13:38
Default Turbulence problem is dead
John Kim
Dear colleagues,
Turbulence has been solved. Soon it will be clear for all.
J. Kim
Old   May 21, 2000, 14:11
Default Re: Turbulence problem is dead
kees rijk
been dead for ages
(since direct simulation)
Old   May 21, 2000, 19:34
Ji
Dear sir,
In our country there is also somebody saying that turbulence has been solved for many times. I think it is a problem of human brain, may be it has no answer anyway! but we can model turbulence for engineering usage.
However I still want to know the details that you said.
Old   May 21, 2000, 20:30
Default Re: That's fine, many are still trying to solve inviscid or laminar flow problems
John C. Chien
(1). Turbulence modeling is one aspect of CFD. (2). There are still enough problems to keep engineers very busy in CFD, such as handling of complex geometry, easy mesh generation methods, fast numerical algorithms, 3-D presentation of results. (3). This requires background in geometry, calculus, 3-D modeling, CAD, numerical methods,aerodynamics, fluid mechanics, heat transfer,combustions, etc. (4). That's should be enough to keep this cfd forum alive. Well, the cold war is still around, not to mention the real war and the conflict with communism. The world is actually becoming more unstable and can easily lead to turbulence.
Old   May 22, 2000, 02:33
Mahesh Prakash
So what if the turbulence problem is dead? The world goes on and cfd goes on.
Old   May 22, 2000, 02:52
Default Please show us the proof. Thank you !
Doru Caraeni
Dear Dr. Kim,
If you are that John Kim (Kim & Moin DNS of channel flow Re 3300), we will believe you if you send us also the proof. Probably you have in mind to characterize the turbulence in terms of statistical properties (as it is a chaotic phenomenon, I can't see any deterministic way of describing the turbulence - I may be wrong?) If you didn't make a joke () it may be the biggest discovery of this century. I can't wait to find out more details! Please, send us some details!
With all my consideration,
Thank you!
Doru
Old   May 22, 2000, 03:44
Robin Bornoff
One man's solution is another man's problem.
Old   May 22, 2000, 10:23
Default Jonas - can you read this?
Mohit Agarwal
Hello Jonas,
I believe that you are the only one who can do this.. Could you please check out the IP address or the site from where this message originated. Curious.. simple reason. Want to know whether it is John Kim (Rockwell International Professor - UCLA) himself.
Mohit
Old   May 22, 2000, 11:48
Default Re: Jonas - can you read this?
Jonas Larsson
Yes, I can check it but I won't disclose it publicly here, sorry - this is not an "abuse" case and I only want to use this kind of information if we have a real problem. The email address given in the orginal message is not the email address of Professor John Kim at UCLA though, draw your own conclusions ;-)
Old   May 22, 2000, 13:11
John Kim
It was brought to my attention that I posted a message saying that the turbulence problem is solved. This message was not from me. It must have been another John Kim at UCLA or an imposter.
John Kim Professor Department of Mechanical and Aerospace Engineering UCLA
Old   May 22, 2000, 13:53
Default Probably the last message in the thread!
  #11
Mohit Agarwal
I believe that this one would be the last message in this thread. People have a general tendency to say things without knowing a bit about those. Take for instance a message posted a couple of days back, titled 'Grid size in LES'. A part of it reads: "In my opinion, LES is the simplist model for (large scale) turbulence." What would anybody reply to that? Funny things!
And if a similar thing is posted under the name of someone who is well known in the field, it is bound to recieve attention. Jin Li - I'm not blaming you for anything, just citing an example.
Although Jonas might say that this not an "abuse" case, I tend to disagree with him on this part. Nothing else.
regards, M.
Old   May 22, 2000, 14:43
Default The problem with "turbulence problem is dead" is dead
  #12
Peter
Hi
I posted the false John Kim message.
Sorry for the joke; I just wanted to see your response.
Of course, turbulence is not dead; this site is a proof.
I won't do it again.
Peter
PS: I almost died of a heart attack when I saw true John Kim Message.
Old   May 22, 2000, 17:46
Default Re: The problem with "turbulence problem is dead" is dead
  #13
Mahesh Prakash
Dear Peter
You had better be a little more prudent the next time you use this forum for such jokes.
Regards
Old   May 25, 2000, 16:38
  #14
MDC
Peter,
I think you have done a really evil thing, although maybe you don't have an evil intention. Seeing that you have admitted so quickly, I suggest that you voluntarily do 2 month service in your community. Remember that God still loves you.
Old   June 5, 2000, 13:50
  #15
Phil Gresho
Is this the JOHN KIM, from NASA/ Stanford, that I know????
Old   June 5, 2000, 15:32
  #16
Jonas Larsson
No it is not. The real "John Kim" posted a response above stating that he did not post the original message. The imposterer has also stepped forward (see replies) and apologized.
Old   June 5, 2000, 17:35
  #17
Phil Gresho
YES; i TOO saw the others....but only AFTER sending mine!! Thx.
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
High Turbulence Intensity Problem bwg FLUENT 1 January 13, 2010 13:09
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
Turbulence boundary values lego Main CFD Forum 0 October 24, 2002 13:47
