-   -   What is Soret effect? (http://www.cfd-online.com/Forums/main/2160-what-soret-effect.html)
Chuck Leakeas April 25, 2000 10:19
Re: What is Soret effect?
The soret effect is where small light molecules and large heavy molecules separate under a temperatue gradient. Usually this effect is important where more than one chemical species is present under a very large temperature gradient such as CVD problems and chemical reactors. This effect is found when solving the species mass fraction equations.
The Dufour effect describes the energy (heat) flux created when a chemical system is under a concentration gradient. This could also be important in CVD problems. This effect is found in the energy equation.
The soret coefficient is the ratio of the thermal diffusion coefficient divided by the ordinary diffusion coefficient.
Jin Wook LEE May 25, 2000 00:11
Dear Zeng
Dufour Effect : Concentration gradients produce a heat flux. Soret Effect : Reverse of Dufour effect
It is known that both Soret & Dufour effects are negligible, for most applications.
Sincerely, Jinwook
s.venkat May 30, 2000 06:00
Soret effect- This is a mass flux due to a temperature gradient and appears in the species continuity equation when you have a multicomponent mixture where each species has its own diffusional velocity.
Dufor Effect-This is enthalpy flux due to a concentration gradient and appears in the energy equation for a multicomponent mixture.These effects depend on thermal diffusion which is generally very small but can be sometimes significant when the participating species are of widely differing molecular weights
Venkat
Zeng May 30, 2000 06:00
Can you help me to understand: (1) Soret effect (2) Soret diffusion coefficent (3) Dufour effect
Thanks in advance.
eslamian June 14, 2012 19:32
soret effect
In isothermal mixtures of two or more species (gases, liquids and even
solids), mass diffusion occurs if the species are initially distributed
unevenly, i.e., when a concentration gradient exists. A temperature
gradient can also work as a driving force for mass diffusion, in a
phenomenon which is called thermodiffusion, thermal diffusion, or in
liquid mixtures Soret (Ludwig-Soret) effect.
Free open access paper on Soret effect
http://www.thermalfluidscentral.org/...hp?a=206&g=242
michujo June 15, 2012 04:04
Hi, as far as I know, Soret effect is not negligible when you compute the transport of light species (typically H radical in combustion applications).
Cheers.
eslamian June 15, 2012 09:44
soret effect
Whenever there is a temperature gradient in the mixture, Soret effect is present. The higher the temperature gradient, the larger the Soret effect. Pressure diffusion is usually negligible but not the Soret effect.
mohsenclick October 11, 2014 16:38
Originally Posted by Chuck Leakeas
;8860
I am confused.....on one side when we have temperature gradient the different species seperate to omit this gradient so temperature gradient decreases but the concentration gradient created as a result....so now due to dufour effect this concentration gradient should create heat flux that will lead to temperature gradient again....and now it is again soret effect turn and this cycle continues.....so when these two effects reach to a balance......?????????????????????????
mohsenclick October 11, 2014 17:14
