June 5, 2000, 07:38 |
quires on turbulent viscosity
i am new to this field of CFD. i have some small quires. 1. can we express the turbulent viscosity for 3D flow using prandtls mixing length model? if so how can it be expressed? 2. in k-e model for turbulence, if k is a function of x,y,z,t and similarly for e, dont u think it there should be 3 equations each for k and e, for complete mathematical closure of the model.?
June 5, 2000, 08:47 |
Re: quires on turbulent viscosity
(1). I think there is a popular algebraic turbulence model called "Baldwin-Lomax model", you can take a look at it. (2). If it is a function of x,y,z,t, then it is four dimensional. The variable is a function (x,y,z,t), and the equation will have derivative terms such as dkdx, dkdy, dkdz, and dkdt,etc.... (3). K and epsilon are not vectors, so each requires only one equation.
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet | Felipeb | Main CFD Forum | 1 | July 26, 2010 17:02 |
Turbulent viscosity and shear rate | shib | FLUENT | 0 | June 22, 2010 12:44 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
