June 16, 2000, 10:00 |
convergence criterion
I am a new phoenics user, can anybody tell me what is the GLOBAL CONVERGENCE CRITERION (default value 10e-4) that is in the NUMERICS menu? I think it is something linked to the residuals but I don't know how it is calculated, does anybody know?
June 16, 2000, 21:06 |
Re: convergence criterion
(1). Don't try to understand the definition. There is nothing you can do there. (2). When I run a commercial code, I always set these numbers (you are likely to have one for each equation being solved) to 1.0E-08 that is 0.00000001 Then you can set it and forget about it. (2). Use the total number of iterations to control the convergence. Check the variables of interest to you at several locations of interest, and plot the convergence history. (3). The flow convergence (steady state) is non-uniform, at some locations it is fast and at some other locations it is very solw. To reach convergence, you must be able to see flat part of the history plots of the variables vs iteration numbers. (4). Let the computer do the number crunching hard work, and make sure that you have the converged solution. (mesh size and quality always has a great impact on the convergence of the solution) Do not accept the solution unless it is the fully converged solution.
June 18, 2000, 03:43 |
Hi Luca,
global convergence USUALLY refers to a volume integration over the entire domain. So for mass conservation it is the sum of all mass flow rates at the boundaries (and source terms) normalized by the inlet mass flow. So 10e-4 is an overall ballance within 0.01%. This is an indication of how well the nonlinear discrete equations have been solved NOT necessarily of the accuracy of the discrete equations in approximating the solution. 1e-4 is typically for industrial work. It is also important to look at the local residuals how well the individual control volume equations have been solved by the nonlinear iterative process. Good Luck..................Duane |
Display Modes | |
Convergence | Centurion2011 | FLUENT | 48 | June 15, 2022 00:29 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 10:48 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
convergence criterion | Dominique | FLUENT | 5 | November 24, 2006 03:36 |
Setting convergence criterion | Vidya | FLUENT | 5 | August 6, 2006 17:46 |
