CFD-Code FloWorks
Old   June 19, 2000, 04:43
Default CFD-Code FloWorks
Tim Franke
does someone has experience with the CFD-module of the CAD-System SolidWorks. I'm interested in physical models, possible applications and overall performance compared with the big codes like Fluent, CFX, StarCD ...
Tim
Old   June 22, 2000, 04:14
Default Re: CFD-Code FloWorks
Anis MAALEM
Hi Tim.
I'm actually testing and benchmarking FLOWORKS99, and FLOWORKS2000 soon, with experimental datas.
I'm doing this works for a company which whishes to use it in SOLIDWORKS2000.
I can say that FLOWORKS99 deals quite good with incompressible, compressible and mixed flows, while it is simple to use.
One of course must use FLOWORKS99 in an appropriate manner in order to obtain good calculation results.
If u want more detailed infos, I'm here.
Anis .
Old   June 23, 2000, 02:13
Tim Franke
Anis,
could you tell a little bit of the code's background ? (Finite volume approach ?, which turbulence models implemented ?, structured or unstructured meshes ? ....) Can you do comparisions to popular CFD-codes ?
Thanks,
Tim
Old   June 23, 2000, 07:43
Default Details ofr Tim ...
Anis MAALEM
Hi Tim,
Finite Volume Method;K-epsilon turbulence model.
Automatic structured mesh generation with cubic control volumes, and local refinement.
Comparison with popular CFD code : FLUENT/UNS.
The main difference is the MESHING. With FLOWORKS99, u cannot generate your own meshing with the amount of cells YOU need, and you cannot visualise it neither to check the accuracy of the autogenerated meshing.
This is a bit frustrating for a CFD engineer.
Meanwhile, FLOWORKS99 does actually show good results in the project I'm working on. The calculations cost a couple of hours. The time cost is to be decreased with the FLOWORKS2000 release as the accuracy is to be enhanced for the same CPU calculation time.
Well, the software is simple to use (u don't have to manage numerical schemes or algorithms). One has to trust the software.
And my job is to benchmark it with experimentation.
It runs not so bad actually, FOR THE PROJECT I'M WORKING ON.
More details ?
Don't hesitate.
Anis .
Old   June 30, 2000, 09:15
Hajo Patzschke
Hi Tim,
Im pleased to hear about your interest in FloWorks. Could you give me some more details about the problems you want to solve? Interested in testing the code? Let me know.
Hajo
Old   June 30, 2000, 09:54
Tim Franke
We want to solve the flow in a rotating vessel including the free surface behaviour. Are there other turbulence models implemented than standard k-eps model ? Is it possible to consider two-phase flow ?
Cheers,
Tim
Thread Tools
Trackbacks are On
CFD Code with Fortran murat Main CFD Forum 0 October 11, 2009 17:05
CFD Code Choice and General Advice Alex Pope Main CFD Forum 26 April 25, 2007 11:54
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
CFD JOBS and Expected Salary.... Noel Harrison Main CFD Forum 11 November 22, 2000 08:15
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
