turbulence
Old   July 10, 1998, 09:15
Default turbulence
Christelle
Hi, I am working with compressible Navier-Stokes equations and I want to compute forced compressible turbulence for Mach number <1..
I would like to have some suggestions or references about the choice of the forcing term. thanks in advance, christelle
Old   July 10, 1998, 10:18
Default Re: turbulence
Jonas Larsson
I'm not sure of what you mean with "forced". Could you please clarify that?
Generally speaking you don't have a lot of compressibility effects on the turbulence for Mach numbers below 1. For flows below the hypersonic range (M ~< 3) you can usually neglect things like pressure dilatation, pressure work and pressure diffusion and just use "incompressible" turbulence models, provided you formulate them in a correct conservative formulation.
I'm working with turbulence modeling for supersonic flows (heat transfer in supersonic turbines, max Mach ~ 2), so I share your interest in compressible turbulence modeling.
Old   July 10, 1998, 11:14
christelle
I will clarify the point "forced compressible turbulence"
I want to compute a isotropic turbulence but not decaying in time . So I must add a forcing term in compressible Navier-Stokes equations to make the flow stationary.
I don't want to get by adding this term non physical compressible effects . The flow must stay incompressible (M<1) and I would like to know wich forcing term I could use to have these properties. thanks for responses. christelle
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
