Anisotropic Adaptation
Old   July 9, 2000, 16:23
Default Anisotropic Adaptation
Apurva
I am a beginer in Grid unstructured generation, till now I have worked on solver and structured grid generation only. I am looking for literature/book on grid generation ( I have already read Thompson & Warsi ) specially concerned with anisotopic grid generation. I also want to know about triangulations and am looking for very basic material for beginners. Please help me for the same.
Regards
Apurva
Old   July 9, 2000, 23:13
Default Re: Anisotropic Adaptation
P.Jawahar
1. W. Kyle Anderson, "A grid generation and flow solution method for the Euler equations on unstructured grids", Journal of Computational Physics, 110, 23-38, (1994)
( I guess it appeared as NASA report also. Check out NASA TM-4295. Explains the step by step procedure involved in 2-D unstructured grid generation using Delaunay triangulation technique. )
2. D.J. Mavriplis, "Adaptive mesh generation for viscous flows using Delaunay triangulation", Journal of Computational Physics", 90, 271-291 (1990).
(You can also search for ICASE reports at http://www.icase.edu. Look for reports published by Mavriplis and/or Venkatakrishnan.
In Particular there is a paper by Mavriplis on "Unstructured mesh generation and adaptivity".)
3. T.J. Barth, "Aspects of unstructured grids and finite-volume solvers for Euler and Navier-Stokes equations", AGARD Report, 787 (1992)
(A well written report which will help you to understand the issues...!)
Good Luck,
Jawahar
Old   July 10, 2000, 17:32
David
If you are interested in commercial anisotropic mesh adaption then have a look at;
http://www.icemcfd.com/mom3d/index.html
Hope this is of interest to you.
regards
David ICEM CFD UK
Axisymmetric 2D mesh adaptation - ERROR Pepe CFX 3 May 30, 2011 08:28
No grid adaptation Pimmie80 FLUENT 1 September 21, 2010 08:35
Anisotropic Tetrahedral Meshing using Gridgen? Turbomachinery Pointwise & Gridgen 2 May 7, 2007 07:13
Anisotropic Thermal Conductivity Saturn CFX 4 January 30, 2007 12:34
mesh adaptation for hexa mesh Pete CFX 4 April 6, 2005 18:43
