Compressibility of water
Old   July 13, 2000, 12:15
Default Compressibility of water
Dusart
Hy,
I'm currently looking for values of the "compressibility factor of sea water", function of temperature and pressure Do you have something on the subject?
Thanks
Old   July 13, 2000, 13:30
Default Re: Compressibility of water
Z T Xie
A handbook of fluid.
Good luck
Old   July 13, 2000, 14:21
Adrin Gharakhani
Or a thermodynamics book.
Adrin Gharakhani
Old   July 13, 2000, 21:27
Jin Wook LEE
Dear Dusart
Compressibility of water is fairly strong function of temperature. (And I remember that very weak function of pressure). You can find the value in the following text.
J. P. Holman, Heat Transfer
The approximate value under room temperature is (2~3)e-04 for pure water, depending on temperature, large at high temperature.
Sincerely, Jinwook
Old   July 24, 2000, 07:08
Lasse Johansson
The isentropic compressibility can be calculated from the sound-speed, the isothermal compressibility from the potential density. For sea water (and the oceanic pressure, temperature and salinity intervals) the standard reference is
Fofonoff, P. and Millard, R.C. Jr
Unesco 1983. Algorithms for computation of fundamental properties of
seawater, 1983. _Unesco Tech. Pap. in Mar. Sci._, No. 44, 53 pp.
some of the algorithms have been implemented in MATLAB and can be found at the MATLAB-manufacturers site.
regards Lasse Johansson
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Considering water compressibility !!!!!!!!!!!!!!!! Bohis FLUENT 1 November 2, 2007 17:56
Compressibility of water vapor ? CFDtoy Main CFD Forum 1 January 3, 2006 18:27
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
