turbulent eddie
Old   October 8, 1998, 07:01
Default turbulent eddie
sakti
hello all
thanks a lot for your attention. I need (long) time to learn !... :>
I'd like to ask again about turbulent eddie :
1. As Jonas & Prabhu said, turbulent eddie is small & vortex can be a large scale structure. I read that there is large scale eddie (contained most kinetic energy) how about that? Can we see the turbulent eddie?
2. I saw the paper about simulation of fluid flow in combustion engine chamber. There were rotasional structure called swirl and tumble. Are these vortex or turbulent eddie (the flow was turbulent) ?
that's all thanks again for the answers
regards
sakti
Old   October 8, 1998, 12:28
Default Re: turbulent eddie
John C. Chien
1). If you take a long-time exposure photo of a turbulent flow , you get sort-of time-averaged flow picture,that is the mean flow picture. 2). If you move the camera at the mean flow speed, those turbulent eddie moving at the mean flow speed will be stationary, relative to the camera, and you will be able to see the structure of these eddie. 3). If you move the camera at a lower speed, you will see only those eddie moving at this lower speed. You will not be able to see the structure of those eddie moving at the mean flow speed at this lower camera speed. 4). Swirl and tumble motion are mean flow motion, which is equivalent to the long-time exposure photo of the flow in a combustion chamber. 5). Swirl and tumble ( rotational motion in two different axis ) are used in the IC engine design to improve mixing and combustion efficiency.
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
Turbulent Boundary Layer on a Flat Plate Hoshang Garda FLUENT 1 November 27, 2013 10:24
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 23, 2010 23:56
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
