SIMPLE
Old   August 7, 2000, 04:54
Default SIMPLE
Alexander Kaps
Hello there,
I am writing a CFD algorithm:
finite volume, incompressible, structured multiblock, collocated variable arrangement.
I need to get more information about the SIMPLE, SIMPLEC, SIMPLER algorithm for collocated variable arrangement and non-orthogonal grids.
In the literature I only found some pieces of the puzzle which do not belong together. Does anyone know an article or book with a detailed discribtion of this pressure correction algorithm (collocated + non-orthogonal)?
Thank you, bye
Old   August 7, 2000, 05:08
Default Re: SIMPLE
mehdi
An Introduction to Computational Fluid Dynamics: The Finite Volume Method
By: Versteeg, H.K. and Malalasekera, W. Addison-Wesley, 1996
Old   August 7, 2000, 12:20
Default Re: SIMPLE
frederic felten
Check the book: "Computational Methods for Fluid Dynamics" Ferziger, J.H. and Peric, M. Springer-Verlag 1996.
The theoritical aspect of collocated grid in non-orthogonal, with pressure correction is well explained, and above all, you'll get an acces to several CFD code, written by Peric, and one of them has all the features you want.
Sincerely,
Frederic Felten
Old   August 29, 2000, 13:12
Default Re: SIMPLE
Antonio Pascau
Hi Alexander, There is a Report by RISO in Denmark whose title is General Purpose Flow Solver Applied to flow over Hills The author is N.N. Sorensen. He uses collocated grid plus SIMPLE in a 3-D domain. It might be of some help for you. You can get it free from RISO at www.riso.dk. Good work!
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver renyun0511 OpenFOAM Running, Solving & CFD 0 November 10, 2010 01:47
How to add correcting pressure equation in SIMPLE of MRFSimpleFOAM? renyun0511 OpenFOAM Programming & Development 0 November 4, 2010 01:38
PISO vs. SIMPLE benedikt flurl Main CFD Forum 2 April 14, 2005 06:54
SIMPLE algorithm Jonathan Castro Main CFD Forum 3 December 10, 1999 04:59
