September 7, 2000, 05:12 |
Solving 2-d problems by 3-d solver
Can we solve 2-d CFD problems by using 3-d CFD codes with periodical boundary condition in third direction?
September 7, 2000, 05:40 |
Re: Solving 2-d problems by 3-d solver
As my experience(use a 3-d code to envaluate the lift of 2-d aerofoil), I let the length of computaion domain in the third direction to be much biger than the other two directions, then I averaged the third direction. It is expensive but maybe much reliable.
September 7, 2000, 06:01 |
You should use symmetry conditions (zero normal derivatives) in the third direction and not the periodic bounday conditions. The third velocity component should be set to zero (Dirichlet condition).
regards DML |
September 7, 2000, 06:15 |
If there is a real 2D configuration you can solve the problem with a 3D-code by setting symmetry boundary conditions at the surfaces in the third direction. Periodic boundary conditions are not really appropriate because this kind of BC does not imply zero mass flux over these surfaces.
icoLagrangianFoam OF1.6 myNewParticleSolver | heavy_user | OpenFOAM | 23 | June 2, 2020 02:18 |
Velocity blows up suddenly after 30,000+ iterations | lordvon | OpenFOAM Running, Solving & CFD | 15 | October 19, 2015 13:52 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
MRFSimpleFOAM goes divergenced! | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | November 19, 2009 02:11 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
