Generalized eigenvalue problem
Old   September 14, 2000, 22:57
Default Generalized eigenvalue problem
z.zeng
I am coding a Linear Stability Analysis for fluid dynamic problem, and therefore a genernalized eigenvale problem A x=lamda B x must be solved. The matrix A is real, diagonal and singular, and B is real, block-diagonal and non-symmetry.
(1) Could you suggest me a good literature or subroutine for Inverse Iteration method for eigenvalue with largest real part ?
(2) Could you suggest me a QR method or subroutine for above genernalized eigenvale problem by considering the storage of spase banded matrix A and B?
Thanks in advance.
Zeng
Old   September 15, 2000, 04:53
Default Re: Generalized eigenvalue problem
Reza Besharati
Hi
If you can take a look at the following book, Handbook for Automatic Computation Volume II; Linear Algebra,J.H. Wilkinson, C. Reinsch, published by Springer Verlag.
Reza Besharati
Gook Luck
Old   September 18, 2000, 00:09
Toyoki Matsuzawa
Hello
Wilkinson's book is the classic for eigenvalue problem. More up-to-date information about large eigenvalue problem can be found in the following book
Y.Saad Numerical methods for Large Eigenvalue Problems
PS files are available on-line http://www-users.cs.umn.edu/~saad/books.html
Also, ARPACK would be good place to start with.
Best Regards Toyoki
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
