Question concerning about the flow simulation of a fan in an engine room.
Old   October 9, 1998, 11:20
Default Question concerning about the flow simulation of a fan in an engine room.
ghlee
Hello! I will begin the new project about the flow simulation in an engine room. In a vehicle engine room, there is a fan in order to cool the interior. Do you know any journal or book related in this theme? Would you like to give a reply? Thanks.
Old   October 9, 1998, 12:22
Default Re: Question concerning about the flow simulation of a fan in an engine room.
John C. Chien
A fan is for low pressure application. Normally, you should have a performance chart which will give you RMP and flow rate. From there, you can derive the exit velocity, uniform, or non-uniform ( if you measure the velocity distribution ). That velocity distribution can be used as a boundary condition on the wall where the fan is located.
Old   October 9, 1998, 12:43
Joern Beilke
Gerald Schmidt (gerald@adapco.com) from Adapco did this kind of simulation for Mercedes some years ago using StarCD. They have also a nice video about this work.
Old   October 21, 1998, 07:05
Fred
You should find some answers to your questions by looking at some automotive industry databases (like Society of Automotive Engineers in US). There have been a lot of studies (both numerical and experimental) as the cooling of the engine compartment is still under research
Rotary Engine Combustion Simulation With SolidWorks Flow Simulator 2009 saaguy FloEFD, FloWorks & FloTHERM 9 December 7, 2010 20:55
Heat Transfer boundary conditions for engine coolant flow simulation rajuks Main CFD Forum 0 February 15, 2010 09:04
Question on Unsteady Flow Ben CFX 5 January 17, 2008 17:04
question on granular flow simulation Derek Jing CFX 0 June 5, 2002 08:58
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
