Street Canyon Flow
Old   September 26, 2000, 08:03
Default Street Canyon Flow
mapplekim
Dear all,
I got some data for street canyon flows from numerical model. I found that there is large irregular variation in Reynolds number with increasing turbulent kinetic energy. Is there any other kind of Reynolds number definition? I hope to get your kind answers. Thanks in advance.
Old   September 26, 2000, 13:39
Default Re: Street Canyon Flow
Adrin Gharakhani
So long as the flow density and viscosity are constant, the "effective" Reynolds number is fixed. Period. Reynolds number is a scaling parameter that comes from non-dimensionalizing the Navier-Stokes equations. The very idea is so that we'll end up with these "constant" scaling parameters. If you are getting variations in Reynolds number then you are doing something fundamentally wrong in your preliminary analysis (non-dimensionality).
Note I stress that the density and viscosity have to be constants. In the simplest case, if, say, you get a kinematic viscosity that is spatially invariant but changes in time, then you get an "effective" Reynolds number that changes in time as well. That is, in front of the Laplacian operator you'll have a term that involves a constant Reynolds number and a time dependent kinematic viscosity, such that their combination gives you a time-dependent Reynolds number.
A "simple" example is the iso-thermal flow, say, in an IC engine (where the piston moves sinusoidally and thus the kinematic viscosity changes in time). In this flow, you can clearly see the "thinning" and "thickening" of the wall boundary layers as a function of time, in compliance with the increase and decrease, respectively, of the "effective" Reynolds number.
In your canyon flow case I doubt you have a similar situation.
Adrin Gharakhani
Old   September 10, 2013, 14:08
Question 3D street canyon simulation
Prashant Thaker
prashantthaker208 is on a distinguished road
i am a new user to Fluent. i am working on pollutant dispersion simulation for a 3D street canyon.
Can anyone guide me regarding how to create the Geometry and the boundary conditions.
Thanx in advance,
prashnat
prashantthaker208 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Kármán vortex street in cavitating flow behind bodies in the cavitation tunnel L. Könözsy Main CFD Forum 0 April 17, 2000 13:16
