about gnuplot or matlab
Old   October 1, 2000, 01:51
Default about gnuplot or matlab
Junseok Kim
How can I use gnuplo or matlab to plot a binary format data file?
Any help would be great except saying look at gunplot manual, I already did that.
Old   October 2, 2000, 06:16
Default Re: about gnuplot or matlab
Sebastien Perron
I dont't think gnuplot can handle binary files. (I've just checked in te manual)
You will need to write a simple driver that read the binary format and translate it into ascii. (This is very easy in C or C++).
As for MATLAB, I've never used it and I can't help you.
Old   October 2, 2000, 18:42
clifford bradford
Matlab uses the fread and fwrite command to read and write binary files.
Old   October 3, 2000, 04:52
Steve Amphlett
I can't comment on gnuplot, but if you can program in C, you can easily get binary data into MATLAB for plotting.
MATLAB provides fopen, fread, fwrite and other C-like I/O library functions - these are OK for small(ish) amounts of data. If you want to do serious binary data import, you can write what MATLAB calls a MEX file. This is your own C code, wrapped by a MATLAB gateway function that allows you to read the data yourself, manipulate it and import it directly as a MATLAB variable. Once you've written your MEX file, using it is really easy. E.g.
>> x=read_my_data('filename');
:> plot(x(:,1),x(:,2));
How to start Fluent with Matlab?? Jay Hu FLUENT 8 November 9, 2022 06:30
Quick OpenFoam to MatLab lesson plz :) Rickard.Solsjo OpenFOAM 6 October 26, 2020 11:58
OpenFOAM command from inside MATLAB sega OpenFOAM Post-Processing 18 September 25, 2012 07:35
2-D Euler Solver for compressible flow in Matlab Volkan Main CFD Forum 1 October 28, 2007 01:40
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 19:51
