Fully developed flow
Old   October 5, 2000, 00:50
Default Fully developed flow
grammi
Hai,
I am studying the fully developed flow between two parallel plates in the presence of a magnetic field applied parallel to the flow direction, whose velocity is U. Should my momentum equation be (sigma)*(Bo)*U or just (sigma)*(Bo).
Expecting a reply
Old   October 6, 2000, 12:13
Default Solution to your problem
Kapil
It would be (sigma)*(Bo)*U
Old   October 6, 2000, 21:55
Default Fully Developed Flow Again
grammi
Thank you for your reply. But here the velcoity U is independent of the flow direction, as you know the flow is fully developed. Therefore I hope the applied magnetic field strength will be a constant as there is no change in the velocity in the flow direction. Your comment in this regard is most welocme.
Sundar
on fully developed duct flow yfyap Main CFD Forum 6 November 7, 2012 09:59
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 22:08
Fully developed flow profile icfd Main CFD Forum 3 May 20, 2009 22:21
udf for 3D laminar fully developed flow salman FLUENT 0 November 9, 2006 21:45
Fully developed flow Yap Wen Jiun Main CFD Forum 1 June 12, 2001 21:23
