October 4, 2000, 06:10 |
Cp of Argon
Anyone can tell me : 1.How much is enthalpy of Argon and Nitrogen at 1000K? 2.And how to calculate enthalpy of Ar and N2 at 20000K(Cp has been known) ?
October 5, 2000, 05:30 |
Re: Cp of Argon
Enthalpy is defined as :
delta h = Int (from Tref to T) Cp dT. So, it is very easy for you to calculate the enthalpy of Ar and N2 because you already know Cp. Sincerely, Jinwook |
October 5, 2000, 17:08 |
Re: Cp of Argon
Jin LEE was right, but note also that in order to answer your question you need to know at what pressure your system is. So again....
Cp = dh/dT (For a constant pressure!!!!) Have Fun... |
October 6, 2000, 04:25 |
Re: Cp of Argon
October 6, 2000, 10:13 |
Re: Cp of Argon
Once I saw a book with all important properties of argon, which I think must also exist for Nitrogen. I think it is from the IUPAC. Unfortunately I don't know more but I am quiet sure that it was published by IUPAC so perhaps it will be helpful to look under www.iupac.org/
Good luck Philipp |
October 6, 2000, 12:37 |
Re: Cp of Argon
I found this link. I didn't go very much further than this but if you follow the information here it should lead you to a program which will calculate everything for you... Lucky!
http://www.lerc.nasa.gov/WWW/DSA/wri...ies/fluid.html |
Sutherland's Law Coefficients for Argon | Michael | Main CFD Forum | 8 | February 27, 2015 05:06 |
Argon gas inside a steel tube? | rskrishna87 | CFX | 3 | April 27, 2011 19:26 |
Gas Properties for Argon and Hydrogen at high Temp | Ralf Schmidt | Main CFD Forum | 0 | October 2, 2007 14:26 |
Gas Properties for Argon and H2 | Ralf Schmidt | Main CFD Forum | 2 | July 30, 2007 09:15 |
Argon properties | Oleg Melnik | Main CFD Forum | 7 | November 7, 2003 04:41 |
