Gas-particle flow turbulence modulation
Old   October 14, 2000, 12:01
Default Gas-particle flow turbulence modulation
Zdravko Stojanovic
Dear Sirs,
I would be thankful for your suggestions on the following problem.
I would like to analyze turbulence phenomena in gas and particles flow in a closed channel. What I need is a 2-D code that I could use as a basis for the analysis of this phenomenon. The resulting code should be used for the analysis of my experimental data.
I am already using a 1-D code with k-epsilon and Reynolds stresses models, but this code is used only for some rough validation. I am not so sure that RANS could be the final approach for the problem at all.
Of course, the code should have some sort of documentation and test examples, so that I could understand in a reasonable period of time.
I would be glad to supply additional information if my question is not clear enough.
Thanks.
Old   October 16, 2000, 05:11
Default Re: Gas-particle flow turbulence modulation
Sergei Zhubrin
You might like to have look at level 2 or higher of PHOENICS Shareware. I believe its powerful 2 phase solver is what you are looking for. The software is available via cfdSHOP along with the relevant documentation.
The inspection of Applications, Input Libraries and PHOENICS Journals of CFD will help to locate the examples (or, may be, exactly your problem) to start with.
Regards
Sergei Zhubrin
Thread Tools
Trackbacks are On
Turbulence postprocessing Mohsin FLUENT 0 September 19, 2011 21:05
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
heat transfer betwen gas and particle eri andika FLUENT 5 December 8, 2003 19:42
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
