help: VOF for multi-fluid flow
Old   October 17, 2000, 22:41
Default help: VOF for multi-fluid flow
Shu-Yi
I am interested in applying VOF to a multi-fluid (more than 3 different fluids) flow problem. So far, I have only seen VOF applied to two-phase (or two-fluid) problems. Can anyone shed some light on how to apply VOF to multi-fluid problems? Any literature exists? Thanks!
Shu-Yi
Old   October 18, 2000, 09:18
Default Re: help: VOF for multi-fluid flow
Jim Park
Try www.flow3d.com. If your problem can't be done by Flow3d, they'll know where to get it done.
That's the web site for Flow Science, Inc. Flow Science was founded by C. W. Hirt, who invented the VOF technique. Flow Science is also a sponsor of cfd-online.
Good luck!
Old   October 18, 2000, 14:32
Shu-Yi (Alter Ego)
I think VOF has enough problems trying to deal with two fluids.
In order to obtain the NS equations in a one field formulation you will have to create an indicator function for three fluids. After this, things should fall into place.
I remember seeing one paper on applying 3 fluids but i'm not too sure if it was using VOF or not. Ill keep a look out.
Sorry I haven't been much help. Happy VOFing.
Old   October 20, 2000, 03:56
Thomas Fuhrich
maybe you will find the following interesting:
Tokyo Institute of Technology:
http://www.mech.titech.ac.jp/~ryuutai/yabe.html
http://ciprus2.es.titech.ac.jp/cipuse.html
Comercial version:
http://www.iijnet.or.jp/cipsoft/index-e.html
- Thomas
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Air-water flow (VoF). Need help :( Luke1984 FLUENT 6 October 19, 2009 09:59
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 16:29
Fouling and Fluid Flow Robert H. Leyse Main CFD Forum 1 January 12, 2003 16:57
