October 17, 2000, 22:41 |
help: VOF for multi-fluid flow
I am interested in applying VOF to a multi-fluid (more than 3 different fluids) flow problem. So far, I have only seen VOF applied to two-phase (or two-fluid) problems. Can anyone shed some light on how to apply VOF to multi-fluid problems? Any literature exists? Thanks! Shu-Yi |
October 18, 2000, 09:18 |
Re: help: VOF for multi-fluid flow
Try www.flow3d.com. If your problem can't be done by Flow3d, they'll know where to get it done.
That's the web site for Flow Science, Inc. Flow Science was founded by C. W. Hirt, who invented the VOF technique. Flow Science is also a sponsor of cfd-online. Good luck! |
October 18, 2000, 14:32 |
I think VOF has enough problems trying to deal with two fluids.
In order to obtain the NS equations in a one field formulation you will have to create an indicator function for three fluids. After this, things should fall into place. I remember seeing one paper on applying 3 fluids but i'm not too sure if it was using VOF or not. Ill keep a look out. Sorry I haven't been much help. Happy VOFing. |
October 20, 2000, 03:56 |
maybe you will find the following interesting: Tokyo Institute of Technology: http://www.mech.titech.ac.jp/~ryuutai/yabe.html http://ciprus2.es.titech.ac.jp/cipuse.html Comercial version: http://www.iijnet.or.jp/cipsoft/index-e.html - Thomas |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Air-water flow (VoF). Need help :( | Luke1984 | FLUENT | 6 | October 19, 2009 09:59 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Expert parameter to stop the fluid flow simulation | KK | CFX | 1 | February 25, 2008 16:29 |
Fouling and Fluid Flow | Robert H. Leyse | Main CFD Forum | 1 | January 12, 2003 16:57 |
