Adjustment between two boundary layers in ansys meshing watertight geometry |
October 3, 2023, 00:00 |
Jose Martin
Rep Power: 5 |
Hi all,
I am creating unstructured mesh using the watertight scheme in ANSYS Meshing, but I am having trouble adjusting the two adjacent boundary layers. Specifically, I would like to control the step transition between them. You can refer to the attached file for clarification. Currently, I only have four cells to work with, but I would like to have, for example, 10 or more. Does anyone know how to achieve this? (The geometry is that of a cylinder with external flow, and I am trying to adjust the boundary layers around the cylinder.) Many thanks in advance and best regards |
October 4, 2023, 01:52 |
Jose Martin
Rep Power: 5 |
I'm feeling a bit stuck on this point, so if anyone has knowledge about this topic, I would greatly appreciate it. Thanks in advance! |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
ANSYS FLUENT watertight meshing work flow support | rajasekhar reddy | ANSYS Meshing & Geometry | 0 | October 30, 2020 07:27 |
[ANSYS Meshing] Ansys Meshing doesn't import geometry correctly | mohsen_23 | ANSYS Meshing & Geometry | 1 | October 1, 2020 02:17 |
[DesignModeler] Ansys Meshing splits geometry lines | Slurm | ANSYS Meshing & Geometry | 0 | March 22, 2017 12:13 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
