ansys & 3d cfd
Old   November 3, 2000, 09:56
Default ansys & 3d cfd
Dimitris Tavernarakis
How is it possible for someone to make a 3D CFD analysis with ansys 5.5.3. My problem is a airplane wing.
Old   November 3, 2000, 13:36
Default Re: ansys & 3d cfd
Evan
You would need to have FLOTRAN to correctly solve your problem. ANSYS itself is very weak in solving fluid flows, basically limited to flows with heat-flow analogies.
Old   November 4, 2000, 20:27
I'm using ansys multiphysics which has flotran and I've already have made several analysis in 2D ( more like Quasi 2D) but my problem is, if I have a 3D drawing where do I apply the boundary conditions.
Old   December 11, 2000, 09:24
Pantelis Kiotsekoglou
Well, first Im happy to find a greek Fluid Dynamicist who is involved in the same problem field as me.
The next are the boundary conditions. Very significant for applying boundary condition is the geometry of the model itself. On Boundary Areas or lines where no fluid is exchanged with the enviroment, all e.g. velocities can be set to zero. Better you type zero in! Before you start generating a model you should already have some boundary conditions, do you?
Old   December 11, 2000, 17:57
For the begining, My boundary conditions are the speed, and the air characteristics. But I don't understand, If I have a 3D wing and nothing else (not even a plane in space)what should I do to make an analysis
Old   December 12, 2000, 07:55
The first most important step before starting an Analysis in CFD is the Definition of a Control Volume. This means you have to create a virtual boundary around your object. The properties of this Control Volume has to be of simple mathematical nature. So that your given boundary conditions are easy to apply.
On the boundary of the control Volume is not allowed to have any gradients of fluid properties or other properties in high- order functions.
Lets take your wing now,first put a big cube around the wing, next, the velocity which the wing is flying with is the boundary condition which you apply on the control volume, in x,y,z directions(first condition). The next one is the velocity of the fluid on the surface of wing geomtry, this is zero! Now you go on and apply a zero speed in each direction on the surface nodes of the wing.
Thats it. Just let the fluid properties be constant over time and temperature, so that the beginning of analysing is very easy. If this calculation has been successfull, go on and change some fluid properties, not to much. Starting a new analysis and so on and so on.
Hope I could help you little bit!
Thread Tools
Trackbacks are On
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 16:34
Can't import geometry file from Icem CFD to Ansys Workbench Julien87 ANSYS Meshing & Geometry 1 July 19, 2011 16:50
ANSYS ICEM CFD Ver11.0 Max CFX 4 October 22, 2008 16:35
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 17:25
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
