-   -   boundary layer of a flat-plate (http://www.cfd-online.com/Forums/main/2775-boundary-layer-flat-plate.html)
dwi s November 8, 2000 20:45
For a smooth flat-plate with zero incident, there must be a laminar boundary layer at initial length. Practically, it will change to turbulent boundary further downstream at certain critical Reynolds number. If I simulate flow over a flat-plate using CFD with turbulence modeling, Is the initial laminar boundary layer automatically calculated ? or Does CFD assume that the boundary layer is fully turbulent from the leading edge ?
TIA for any reply
dwi
manishkumar.P November 9, 2000 02:45
Re: boundary layer of a flat-plate
hello; the condition you refer is explained in the case of the prandtl-meyer expansion wave analysis in the book :COMPUTATIONAL FLUID DYNAMICS" BY JOHN ANDERSON. CFD does not assume it . the case has to be accounted for with the formula given therein. if i have got you clear. are you dealing with flatplates subjected to hypersonic flows? manishGP.
