December 4, 2000, 19:11 |
ALE method?
Hi, everyone:
I have a bisic question: Under what circumstance it is better to use the ALE method? Thanks! |
December 5, 2000, 14:32 |
Re: ALE method?
ALE is used when there are moving interfaces in the field (crack propagation, two-phase flows etc.). Note however that most ALE methods are only 1st order accurate.
December 14, 2000, 15:00 |
Re: ALE method?
We make an extensive use of ALE methods for coupled fluid structure problems ranging from large deformations of the structure (like crash of a fuel tank) to very small vibrations (like exhaust pipes for noise analysis). The structure is modeled using Lagrangian formulation as usual and the Fluid uses ALE. In this case, the ALE grid is attached to the structures and deforms whenever the strucure undergoes a deformation. You can quite a few exemples on our website www.mcube.fr under the M-Explicit section.
Dimitri Nicolopoulos MCube |
Arbitrary Lagrangian-Eulerian (ALE) Method | tikes | Main CFD Forum | 11 | October 1, 2013 06:05 |
OpenFOAM-1.6 install cookbook | MadsR | OpenFOAM Installation | 372 | November 20, 2010 12:57 |
Deforming grid - ALE method | CFD Student | Main CFD Forum | 1 | October 10, 2006 11:33 |
ALE method | Anne | Main CFD Forum | 3 | January 27, 2005 09:17 |
ALE Method | Anne | Main CFD Forum | 7 | January 8, 2005 05:47 |
