-   Main CFD Forum (
-   -   velocity B.C. (
Pendy December 13, 2000 08:14
velocity B.C.
When using staggered grids and the wall is moving(the moving speed is predefined),how to find the u velocity(nearest and parabel to the wall)? pls help me.
frederic felten December 13, 2000 21:31
Re: velocity B.C.
hi there,
I assume that the wall that you're talking about is moving in a streamwise direction. If so, the wall movement in this direction (X-direction) is felt by the fluid by a change in the wall shear stress. Its value is adjusted by replacing the velocity Up by the relative velocity Up - Uwall. You still have Vwall= 0.0 and Wwall= 0.0 if the wall is not moving in the wall normal direction and the spanwise direction.
i hope this helps, sincerely,
Frederic Felten.
Pendy December 13, 2000 22:58
Re: velocity B.C.
thanks there,
what you said is right if relative motion can be used,but it cannot work with my study,the predefined velocity of the wall is neither normal nor parallel to the wall,I am now dealing with a flow passing an moving object.
Thanks and waiting for help
Ghanshyam Singh December 14, 2000 12:19
Re: velocity B.C.
I think you are solving a problem of flow past a rotating cylinder. I will do the following:
(1) Take very fine grid near the wall. (2) Take velocity of the wall (V=Omega*Radius), deduce normal and tangential components using this velocity. Angle you can obtain using grid line. This again means that first grid point is having the same absolute velocity as that of the wall.
Please correct if I am wrong.
