Water flow into boat
Old   December 20, 2000, 06:37
Default Water flow into boat
GusP
Being a recreational fisherman, I have the following question. How much water would flow (gal per second) into a boat, if it had a 1" square hole in the bottom and the bottom is 18" under water? What I'm trying to do is to size bilge pump capacity. Could you provide the formula and constants that determine the results. Thank you in advance.
Old   December 20, 2000, 09:25
Default Re: Water flow into boat
Rich E
For small appertures :
Volume flow rate = Cd x A x sqrt(2 x g x H)
Cd : discharge co-eff (about 0.6 for water through a sharp edged hole)
A : hole area g : 9.8 ms-2 H : height of water
Old   December 20, 2000, 18:23
GP
Rich, thanks for responding. I have question about the constant "g", what is it, what are the units? Thanks
Gus P
Old   January 2, 2001, 04:42
Rich E
g is gravitational acceleration = 9.8 meters per secondsquared
Simple Water Tank Transient 88phil88 CFX 5 March 17, 2014 03:48
hot water flow into a lake/river waters OpenFOAM 0 January 21, 2011 09:49
Free - Surface Flow: Split Fluid Forces acting on a Boat Hull eee CFX 2 August 28, 2009 08:36
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
