November 17, 1998, 05:07 |
Launder & Sharma model in combusion case
Hi. Does anybody have any experience with the Launder & Sharma low Re number turbulence model, in conjunction with combustion (nonpremixed) modelling (using the SCRS/pdf approach). I find that soon after 'switching on' the combustion model, the simulation crashes due to a zero in a denominator somewhere. Very small under-relaxation factors and numerous sweeps of the continuity equation do not seem to help. The combustion algorithm is correctly implemented because the simulation works properly when using the standard k-e model.
Any suggestions would be greatly appreciated. Thanks, Richard |
November 17, 1998, 19:59 |
Re: Launder & Sharma model in combusion case
Dear Richard
Perhaps you could check the value of the variable. Ex turbulence reynold number, y+ value, turbulence viscosity, the turbulence kinetic energy and turbulece dissipation and the corresponding coefficients value first. |
Display Modes | |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
Euler-lagrange or Euler-Euler Model? Wich is the best for this case | juliom | CFX | 4 | September 4, 2014 08:31 |
k-e turbulence model for 3D case | Serge A.S. | Main CFD Forum | 7 | September 10, 2007 12:50 |
Test Case for Multiple Reference Model (MRF) | CFDtoy | Main CFD Forum | 0 | May 9, 2007 12:45 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
