January 2, 2001, 08:08 |
boundary conditions for K and Epsilon
I make modeling of the air flows in the greenhouses with the model K-epsilon and I ask you which values for the boundary conditions I must put in inlet for the turbulent kinetic energie (k) and for the dissipation of this energie (epsilon)?
January 2, 2001, 10:07 |
Re: boundary conditions for K and Epsilon
What is the Reynolds number in your case? Just to begin with, you can assume turbulent intensity around 5% at the inlet. Calculate K and epsilon based on this and compare the results with the experimental data. You may get reasonable match.
GS |
January 3, 2001, 00:22 |
hi,
To start with as mentioned by Ghanshyam u need to know typical values of turbulent intensity in flows u are solving. then assume some value of eddy viscosity say Mu_eff=20*Mu_laminar (to be correct molecular viscosity) then calculate k as k_inlet= (U_in*TU)**2 Tu=turbulent intensity. U_in=sqrt(u*u+v*v+w*w) e_inlet= (Cmu*rho_inlet*(k_inlet)**2)/Mu_eff hope this helps abhijit |
k epsilon boundary conditions for pisofoam ras solver | chamoun | OpenFOAM | 4 | May 10, 2011 05:30 |
Boundary conditions at Inlet for k and epsilon | Tanmay | FLUENT | 1 | January 26, 2009 10:42 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
