how to compute the gradient of a function
Old   January 5, 2001, 09:19
Default how to compute the gradient of a function
zhanglei
the value of the function f is known on each grid point, to approximate the gradient of the function f, i.e. (df/dx, df/dy) which is the good choice, central difference? or one-sided difference? or some more complicate form?
Old   January 5, 2001, 12:02
Default Re: how to compute the gradient of a function
John C. Chien
(1). It depends on the nature of this function. (2). In principle, the central difference is more accurate than the one-sided difference, based on the Taylor series expansion. (2). Most numerical analysis books have a chapter on the numerical interpolation. And if you are dealing with test data, with some random distributions, then you will have to create a new approxmate smooth function first, in order to derive the general trend or gradient.
Old   January 10, 2001, 08:11
peter.zhao
For finite differnece method,the central difference is usually used to calculate the gradient on account of the accuracy.Meanwhile,for finite volume method,it is better to use Gauss integral theorem over a control unit to calculate the gradient than central differnce.For example,when you calculate the derivative of velocity on the cell interface for viscous term in the N-S equations,the central differnce only takes account of one direction,i.e.you deal with the thin layer N-S eq or PNS,but the Gauss integral considers all direction,i.e.you deal with the full N-S eq.
surface tension as function of normal gradient tom FLUENT 2 September 7, 2016 03:48
get velocity gradient with a boundary function Chris Lucas OpenFOAM Programming & Development 4 August 27, 2012 03:11
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
User defined function for density gradient ben akih CFX 3 October 10, 2006 21:47
How to compute gradient for non-orthogonal grids? Paul Hsieh Main CFD Forum 3 November 11, 2003 04:52
