February 1, 2001, 12:34 |
Stability for Nonlinear Numerical Scheme
It is usual for the application of Von Neumann or matrix methods in the stability analysis of a numerical scheme for a linear PDE. But Neuman method can only be used for linear problems. For nonlinear problem, for example Du/Dt = -(1/2)D(uu)/Dx - 32 (Du/Dx)^2+D^2u/Dx^2, Neuman method can not be used. How do we do the stability analysis for this kind of nonliear PDE after disretization, or where can I get reference materials on this issue?
Thank you! |
February 6, 2001, 09:59 |
Re: Stability for Nonlinear Numerical Scheme
If you write the discretized non-linear equation assuming a first order perturbation
U=U0+deltaU you can linearize the equation (after the discretization). WOuld that help you ? Patrick |
February 7, 2001, 11:51 |
This problem was addressed by Poinsot and Candel for the inviscid Burgers-Equation in Journal of Computational Physics, vol. 62, 282-296, 1986.
February 12, 2001, 12:21 |
Culbert Laney discussed this in great detail in Chapters 15 and 16 of his book Computational Gasdynamics. In fact the linear stability is still relevant.
Numerical viscosity due to the MUSCL and HLL coulpled scheme | sonsiest | Main CFD Forum | 0 | May 23, 2011 15:37 |
How to implement a numerical scheme by using UDF? | Furui Xiong | FLUENT | 0 | July 29, 2010 01:30 |
problem about numerical scheme in LES. | libin | Main CFD Forum | 4 | July 1, 2004 04:32 |
the numerical scheme for LES. | John S | Main CFD Forum | 2 | March 14, 2004 07:52 |
numerical scheme | ado | Main CFD Forum | 3 | October 12, 2000 08:20 |
