V2F turbulence model
Old   February 12, 2001, 03:32
Default V2F turbulence model
Mark Render
Hi all,
could someone share his experience with the use of the V2F turbulence model with regard to the performance in separated flow regime and numerical robustness ?
Thanks,
Mark
Old   February 12, 2001, 11:28
Default Re: V2F turbulence model
John C. Chien
(1). What is V2F turbulence model? (2). Is it a two equation model? high Reynolds number model? or Low Reynolds number model? (3). Another black box code?
Old   February 12, 2001, 17:33
Kuochen Tsai
V2f is a 4 equation relaxation model. Besides k and epsilon equations, it also solves velocity fluctuations perpendicular to the streamline and a global relaxation function f. The prediction for separation flows is much better in genreal. But the model requires resolution all the way to the wall without wall function approximation, which is lot more expensive.
Old   February 12, 2001, 18:51
John C. Chien
(1). So, it is a four-equation, low Reynolds number k-epsilon model. (2). And it is likely to have the same Y+=<1 constraint at the wall?
Old   February 13, 2001, 02:24
Jens Chr. Bennetsen
Well the v2f model is more costly than the more or less standard low-Re k-e model. But only about 20 - 25 %.
So compared to Full Reynolds Stress model is rather cheap. And it does performe better than RSM (my point of view).
Regards
Jens
Old   February 13, 2001, 06:11
sylvain
To begin with take a look at :
P.A. Durbin - "Near wall turbulence closure without 'damping functions'" - Theoret. Comput. Fluid Dynamics, 3 , 1-13, 1991
If you want to know more about test cases involving this model, take a look at :
R. Manceau & S. Parneix - "Computations of turbulent flows using the V2F model in a finite element code" - Engineering Turbulence Modelling and Experiment 4, 319-328 - W. Rodi and D. Laurence (Editors) - Elsevier - 1999
An extension of the elliptic relaxation to RSM models is introduce in :
D. Laurence and P. Durbin - "Modeling near wall effects in second moment closure by elliptic relaxation" - C.T.R. Proceedings of the summer programm 1994, 323-338 - 1994
I do believe that there is also an article in the J.F.M. from P. Durbin.
Several CFD codes editors are going (or have already) implement this model.
Old   February 13, 2001, 15:11
Default Re: V2F turbulence model, thanks
John C. Chien
(1). Thank you for the information.
Old   February 14, 2001, 02:58
Mark Render
Hi Jens,
what type of flows did you calculate with the V2F model ? What were you experiences concerning physical correctness (e.g. prediction of separation) and numerical robustness ?
Thanks,
Mark
Old   February 15, 2001, 09:17
Jens Chr. Bennetsen
Well, most basic flow since I am currently implementing this model into oure reserach code.
Stuff like Backfacing step, simple room geometry, cube in a channel.
But Star-CD has just release an add-on modul with the turbulence model and they have reported 20 % increase in cpu time.
So I think my 20 - 25 % is within limits.
About the physical correctness I have good experience, especially for separations point in transient simulation. And also numerical it is good, I have not observed any problem once it has been correct implemented.
Regards
Jens DIAS
gamma-ReTheta turbulence model for predicting transitional flows FelixL OpenFOAM Programming & Development 123 August 30, 2022 11:50
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 20:21
v2f Turbulence Model (and others?) Travis FLUENT 4 January 7, 2009 01:18
v2-f turbulence model in CFX? flga CFX 14 November 23, 2006 06:12
Turbulence model Herry Phoenics 1 May 29, 2003 13:19
