Sand filter modeling?
Old   March 2, 2001, 09:05
Default Sand filter modeling?
Justin case
I wish to model the flow of a liquid through varying layers of sand in a filtration bed. How in general would this problem be approached and is it possible. Any help is appreciated. thanks
Old   March 4, 2001, 22:53
Default Re: Sand filter modeling?
Newbie
I am modeling a closely related problem using an Eulerian approach. It works relatively ok. Hope this helps
Sincerely A.
Old   March 5, 2001, 06:42
Jin Wook LEE
Eulerian multi-phase model is appropriate one because your sand layer is varying. However, Eulerian multi-phase modeling is very difficult and require extensive computing work. Simple single(liquid) phase calculation somtimes might be very good approximation if your sand layer is varying not rigously. In this case, porous medium approach is common one.
Sincerely, Jinwook
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 11:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 14:49
Solid Modeling Chris Main CFD Forum 10 July 2, 2002 07:12
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
Extrusion Modeling Elliot Schwartz Main CFD Forum 1 September 11, 1998 19:08
