February 16, 2001, 11:47 |
Vortex-Shedding Flow at High-Reynolds Number
Hi Dear friends,
In recent days, I have been simulated the behaviour of the flow behind a square cylinder. My code uses RANS and two K-Epsilon models (the standard and Low-Reynolds). With both the models, the two-vortex row does not persist in the wake. My question is: is this behaviour correct? Thanks. Ferreira. |
February 16, 2001, 13:44 |
Re: Vortex-Shedding Flow at High-Reynolds Number
(1). Fill your bath tub with water. (2). Move the square cylinder stick through the surface of the water in a steady stroke. (3). Observe the wake behind the square cylinder. (4). Spread some baby powder on the surface to aid the observation. Estimate the Reynolds number and check the result. (5). Effect of Reynolds number? You will have to run a real test to find out.
February 23, 2001, 12:36 |
Your RANS simulation is doing what it is designed to do with the k-eps. (an eddy viscosity) model - all unsteady turbulent motion, and the unsteady vortex shedding, is smeared out with the large eddy viscosities thrown into the simulation just behind your square through the use of the k-eps. model. As a result, the unsteadiness that occurs in real life can't be reproduced
At best, what you can expect from your RANS simulation using the turbulence model is something that is close to the long time average of the real flow. |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
Low Reynolds number flow | Terje | CFX | 3 | June 20, 2007 08:10 |
Reynold's number and incompressible flow | Neil | Main CFD Forum | 3 | October 24, 2006 08:11 |
high rayleigh number flow | toni | CFX | 1 | July 31, 2001 00:54 |
Difficulties in solving a high Reynolds number Flow? | wowakai | Main CFD Forum | 10 | December 29, 1998 13:46 |
