March 8, 2001, 05:52 |
L-U decomposition of block matrices!!
hello!! I am trying to solve a tri-diagonal block matrix system by L-U decomposition.I'd like to test run my algorithm...where can i find test data?
For A.X = Y I tried to rig up some data by considering a 5X5 system where each element in the A is a 2X2 matrix(25 elements) and each element of X and Y is a 2X1 matrix(5 elements each)...i considered some 2X1 matrices as the elements of X and then rigged up some coeficient matrices and the corresponding the Y matrices.But my algorithm gave me a set of 2X1 matrices which satisfy the equation but are different from ones that i used to construct the equation!! Does this mean that det(A)==0 ??....please shed some light! thanx radhakrishnan |
[ICEM] Quest for seemingly simple Blocking (degenerate block) | la7low | ANSYS Meshing & Geometry | 0 | July 12, 2011 19:48 |
Incomplete LU decomposition for positive defined matrices | abelme | Main CFD Forum | 0 | November 2, 2010 08:56 |
Block matrices vs segregated solvers | fisher | OpenFOAM Running, Solving & CFD | 9 | June 13, 2010 04:15 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
blockMesh: block with 6 vertexes | dani | OpenFOAM | 3 | June 25, 2009 13:13 |
