Turbulence Model and Accuracy of convective flux calculation
Old   November 14, 1998, 15:56
Default Turbulence Model and Accuracy of convective flux calculation
Lokesh Agrawal
HI,
We are using pseudo-compressibiliy method for solving heat trasnfer problem. We are using SST (Menter 1994) turbulence model and the code is giving convergence and good results for mixed convection in a driven cavity. However, the code is not converging for Natural convection problem (Ra = 10^11)(The results for Laminar cases are excellent in aggreement). At present we are doubting the convective flux calculations (at present central differencing with fourth order dissipation is used). We would like to know whether we are thinking in the right direction or not. Also if someone can suggest some better way of handling the whole affair.
Thanx Lokesh
Old   November 14, 1998, 23:24
Default Re: Turbulence Model and Accuracy of convective flux calculation
wei zhang
Hi, I had some experience about Pseudo-Compressibiliy method, when I worked at Japan(6 years ago). I felt that the result of P-C method is very depended on the Pseudo-Compressibiliy corfficient( usual call BATE).Please try to change the value of BATE, you may get a good result. wei zhang
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Fluent 12 k-w SST turbulence model DarrenC FLUENT 0 December 13, 2009 08:33
v2f Turbulence Model (and others?) Travis FLUENT 4 January 7, 2009 01:18
turbulence model for vortex flows Günther Hasse Main CFD Forum 16 October 24, 1999 12:08
