March 2, 2001, 10:05 |
Sand filter modeling?
I wish to model the flow of a liquid through varying layers of sand in a filtration bed. How in general would this problem be approached and is it possible. Any help is appreciated. thanks
March 4, 2001, 23:53 |
Re: Sand filter modeling?
I am modeling a closely related problem using an Eulerian approach. It works relatively ok. Hope this helps
Sincerely A. |
March 5, 2001, 07:42 |
Eulerian multi-phase model is appropriate one because your sand layer is varying. However, Eulerian multi-phase modeling is very difficult and require extensive computing work. Simple single(liquid) phase calculation somtimes might be very good approximation if your sand layer is varying not rigously. In this case, porous medium approach is common one.
Sincerely, Jinwook |
Display Modes | |
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 12:48 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 15:49 |
Solid Modeling | Chris | Main CFD Forum | 10 | July 2, 2002 08:12 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 10:21 |
Extrusion Modeling | Elliot Schwartz | Main CFD Forum | 1 | September 11, 1998 20:08 |
