Temperature plot
Old   March 8, 2001, 03:48
Default Temperature plot
Clueless
I am currently doing a flow problem which involves convection in a rect. enclosure. My vertical walls temperature are at a non-dimensionalised 1 and 0 on each end respectively. temperature at top is 0.5 while the bottom wall is insulated. However, my temperature plots shows that there are certain points which are negative in value. Is this possible?
Old   March 8, 2001, 07:49
Default Re: Temperature plot
Sebastien Perron
Physicaly, this is impossible if you have no source term. But, it is possible to obtain such values with numerical methods. This might be caused by improper discretisation of the convection term. In order to ensure stability, numerical dissipation must be added. It can be explicit or implicit. If precision is not an issue, I suggest using an upwind sheme. If you want more information, you could give us the type of method that you use (FDM, FVM, FEM, FVEM, ...).
Old   March 8, 2001, 08:08
Clueless
For the vorticity transport equation, ADI scheme is ultilised. GS-SOR was used for the streamfunction. As for the energy transport equation, i am using point iterations. Could it be that i have to use ADI for the energy transport equation as well to get unconditional stability?
Old   March 8, 2001, 08:17
Sebastien Perron
No I don't think so. Since the space discretisation nmight be the cause of you problem, An upwind scheme will give good results..
Thread Tools
Trackbacks are On
plot bulk temperature of fluid mohammadkm FLUENT 4 December 13, 2011 15:37
plot temperature vs time in paraview - chtMultiRegionFoam phsieh2005 OpenFOAM Paraview & paraFoam 0 April 30, 2010 16:31
Temperature Vs time Plot Bikash FLUENT 3 September 10, 2004 06:46
temperature contour plot is discrete (why)? susan_w_b FLUENT 0 January 5, 2004 03:36
Plot temperature profile David FLUENT 3 October 31, 2003 06:30
