Nose singularity of blunt body grids
when generating grids for symmetric blunt bodies (one block) a singularity is imposed at the nosetip. My question is if there is a way to get rid off this singularity or simplify somehow the treatment of this single point in the code. Thanks for your help. |
Re: Nose singularity of blunt body grids
Ah, this can be a bit of a problem. Here's how I've seen it done before.
Just use your normal grid format ( I assume you're using 3-D structured grids ). For the grid cells at the singularity, they will have one side collapsed to a line, in effect a five-sided rather than a six-sided cell. The trick is to still treat it as a normal six-sided cell, don't bother treating it as a special case. Just make sure that when you are calculating the area of this (collapsed) face you get a zero value, then ensure that this results in a zero flux contribution across that face. This may be a bit tricky if you have a viscous scheme but if you stick to the principle you should be ok : don't invent special treatments, just make sure your normal treatment does the right thing when it finds a zero cell area. It's hard to be more specific since different codes work out fluxes in different ways. I hope that helps. |
