Example of SIMPLE-Algorithm
Old   March 19, 2001, 08:20
Default Example of SIMPLE-Algorithm
Peter Karr
does anyone know a reference where the solution of the Navier-Stokes equation using Finite-Volume method using SIMPLE is shown by means of an example that is calculated all the way by hand ? (e.g. 2D-Domain with 3 x 3 control volumes)
Cheers,
Peter
Old   March 23, 2001, 18:37
Default Re: Example of SIMPLE-Algorithm
Bubba
Sorry but, why would you want to do that?
If you are developing a SIMPLE code then look at the book Computational Methods for Fluid Dynamics by Ferziger and Peric.
They give access to the source code for 2-d and 3-d codes...
Old   March 26, 2001, 02:14
Peter Karr
From my point of view you can understand the method better, if you can follow an calculated example ! Even it might be quite large although only 9 2D-cells are involved.
Cheers,
Peter
Thread Tools
Trackbacks are On
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver renyun0511 OpenFOAM Running, Solving & CFD 0 November 10, 2010 01:47
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 0 August 7, 2003 12:58
SIMPLE algorithm Jonathan Castro Main CFD Forum 3 December 10, 1999 04:59
